ABS problems
Old Aug 24, 2010 | 02:27 PM
ram-fjallasport's Avatar
ram-fjallasport
Default ABS problems
now I have some real problems.
can anyone help me?
I changed my wheel hub with the ABS sensor, then the ABS system went wild. The ABS pump started to pump when I touched the brake pedal!
I did not have time to wait for a new hub so I pulled the fuse #6 (ABS motor). This made the brake and ABS lamp to light. but that is ok as long as I have brakes.
Now that I wanted to change into a new hub I did try to put back the fuse. to test if the ABS system stil went wild. But now the ABS system still dont work. I still have the same light in my instruments.
anyone have any idea about what go wrong. I believe the ABS-system can work without ABS pump for a while, or was this a serious stupid thing to pull that fuse #6.
