which one?
Old Aug 25, 2010 | 01:18 AM
Atwiss's Avatar
Atwiss
Default which one?
i want to drop the rear of my truck but dont know how much i want it as level as i can get it, just wondering if i should get a 1.5 or a 2.0 drop shackles
http://moesperformance.com/index.php...ducts_id=10192
http://moesperformance.com/index.php...ducts_id=12307
Old Aug 25, 2010 | 01:50 AM
Marx's Avatar
Marx
get the 2 inch drop and you can keep your overload springs 1.5 is not enough
Old Aug 25, 2010 | 01:55 AM
Atwiss's Avatar
Atwiss
k thats what i was thinking is there anything i need besides the shackle kit
Old Aug 25, 2010 | 02:01 AM
Marx's Avatar
Marx
not sure better let a lowed guy answer that btw there is a lowered sticky thread
https://dodgeforum.com/forum/3rd-gen...-and-info.html
Old Aug 25, 2010 | 09:14 AM
cwboyjohnny24's Avatar
cwboyjohnny24
Most people I've seen with the 2" still doesn't give you true level unless you also take out the o/l spring.
Old Aug 25, 2010 | 09:21 AM
Atwiss's Avatar
Atwiss
will it need to be replaced or do i just remove the over load spring
Old Aug 25, 2010 | 10:06 AM
cwboyjohnny24
You do the 2" drop shackles, then you just remove the over load spring. JusJay has done this and his truck is completely level. Unless you do some pretty good size hauling in the back it won't make a difference taking it off. If you do load the bed and you're concerned about it, you can get some air bags to help with any sagging. They sell normally for around $200.
Old Aug 25, 2010 | 10:56 PM
Atwiss's Avatar
Atwiss
thanks how hard is it to remove the overload spring
Old Aug 25, 2010 | 11:27 PM
TXhemi5.7's Avatar
TXhemi5.7
Hey man in this link the white truck just put on 2" drops and it is not leveled.
https://dodgeforum.com/forum/3rd-gen...-info-150.html
Old Aug 25, 2010 | 11:56 PM
Atwiss's Avatar
Atwiss
where can you get a three inch drop and how much is it and will removing the overload spring make a difference with the 2 inch shackles
