04 1500 quad cab exhaust
Old Aug 26, 2010 | 11:21 AM
1brown's Avatar
1brown
Default 04 1500 quad cab exhaust
hey, im looking to install dual side exit cat back exhaust. any suggestions? dont want to remove spare either.
Old Aug 26, 2010 | 11:27 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
So what exactly are you wanting to know? Can it be done? Sure it can. My first exhaust setup was a catback dual and went right down both sides of the spare tire. You just have to find someone with good bending equipment and skills.
Old Aug 26, 2010 | 11:31 AM
1brown's Avatar
1brown
ok. did you buy name brand and have them bent or did you buy custom? was yours straight back or side exit?
Old Aug 26, 2010 | 11:36 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I bought my own FM Delta 40 on ebay and two tips and took it to a shop and let him bend and weld everything together for me. He charged 150 to bend and weld. I had no custom pre-bent kit.
Mine was straight back but if you are wanting behind the tires then thats fine. You just cannot go before the tires because of the fuel tank on the drivers side
Old Aug 26, 2010 | 11:38 AM
1brown's Avatar
1brown
nice. will look into. thanks
Old Aug 26, 2010 | 05:37 PM
Bowhunter2819's Avatar
Bowhunter2819
@ WEEDAHOE
What the largest diameter that the Hemi will take cat back with out throwing codes all the time?
Old Aug 27, 2010 | 07:38 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
no more than 3" for a single exh and no more than (2) 2.5" for duals (true duals or cat backs). You wont get codes for too big of a pipe but if you move, lose, change or gut the cats then you might get codes.
