trany prob
Old Aug 29, 2010 | 05:27 PM
outcast's Avatar
outcast
Default trany prob
i missed the t in the road and drove off into the ditch put it into reverse to back out thought i was spinning tires but i guess the trany was slipping finaly got out of the ditch and wouldnt go foward until about 2000 rpm made it about a mile down the road wouldnt move at all
took trany out and had someome rebuild it put in new torque converter and everything put back in wont do anything now before i took it out the tail shaft would turn without a load on it but with a load on it wouldnt turn at all the rebuilt trany wont turn the tail shaft with no load at all
any ideas wats wrong ?
check eng light on but it says for o2 sensor
Old Aug 30, 2010 | 07:33 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
First of all, please use punctuation as it makes your posts more easy to rear. Its hard to understand what you are saying or asking when you have to read it 10+ times to understand where one sentence ends and another begins.
Are you sure this "someone" rebuilt it correctly?
When you say it will not do anything, does to engage at all?
Did you reconnect all the electrical plugs and sensors?
Im assuming you are saying without the tail shaft it will spin but with it, it will not? Right? So you either have an issue in the tail shaft or the rear end right? If you put it in neutral will the truck roll?
