Old Aug 5, 2015, 09:20 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Cooling System Guides
Print Wikipost
Water pump change - any advice?
Old Sep 7, 2010 | 06:59 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Yes the fan nut goes CCW and as the the new tensioner being stiff to turn, could be just because it is new still and not worn out....
I put a big wrench on my fan nut, wedge the pulley and hit the wrench with a rubber mallet. It broke loose after a few hits.
Old Sep 7, 2010 | 09:23 AM
bigbran's Avatar
bigbran
Post
Man....I tried that. Like I said, wedged the pulley with a screwdriver and allen key and I actually bent the holes out on the pulley. Now as I drive I can hear a different noise from the engine compartment which I am attributing to the holes being bent out and probably catching some extra air. I even put a break bar on the end of the wrench (after trying with a hammer first) and still couldnt crack it. I have made an appt at the garage for tomorrow since I cant seem to crack the bugger.
Thanks again for all the help. I guess I will have to wait for the next one to tackle!
Old Sep 9, 2010 | 02:10 PM
bigbran's Avatar
bigbran
Well ended up getting the shop to do it for me.....as i took another try at it without any success.
Picked up an idler pulley today though and went to install. Noticed it is a bit biggger compared to the original. Maybe an 1/8" bigger. The parts store I picked it up at says that its the one recommended. Would it make a difference?
Old Sep 9, 2010 | 03:38 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I dont see how that little difference would hurt anything. Bigger pulleys just turn slower is all.
Old Sep 9, 2010 | 06:49 PM
MikeHTally's Avatar
MikeHTally
Sounds good and yes those two smaller hoses are heater hoses. Some guys also use an aspirin to wedge and hold open the stat so any air can pass through. Eventually the aspirin will dissolve and close the stat.
Will that keep the engine from having a "head" ache?
Old Sep 9, 2010 | 07:47 PM
bigbran's Avatar
bigbran
Guess I wondered about tension on the belt....but since the tensioner is spring loaded I suppose it would make up for it. Guess all I can do is try it out?
Thanks to all that replied! Love this forum
