few problem and im lost
Old Sep 5, 2010 | 03:55 PM
jasonball's Avatar
jasonball
Default few problem and im lost
so I here are the problems i'm haing.
the ac blower unit comes on and off when it wants. but will stay on if I position my steering wheel all the way. or I jiggle the key it will come on. there is a lot of play in my ignition so I'm thinking that might be the problem.
2. under low load or just creeping my rpms tend to drop to where the trucks stalls out. I'm thinking this might be an issue with IAC motor. what do you guys think.
bTW it is a 4.7L.
Old Sep 5, 2010 | 08:19 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Well you are right about the ignition switch being bad. As for the RPM issues, there are a few things you could try including cleaning the back side of the throttle body
Old Sep 6, 2010 | 12:25 AM
jasonball's Avatar
jasonball
I'll look in to that. thanks. what part of GA are you from
Old Sep 7, 2010 | 08:44 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
PM sent
