02 with 4.7 won't hold its idle.
Old Sep 6, 2010 | 11:35 AM
InspectorVol's Avatar
InspectorVol
Default 02 with 4.7 won't hold its idle.
Will idle at start up to 1,000 rpm, then it will drop to 800rpm, then to 600, and then on the next drop it will die just like you cut the switch off. Also you can keep it running with the accelerator but will always die when you let off the gas.
Will start right back up but you will have to pump it a little.
Also I think I noticed that it smelled like it was running rich.
Old Sep 6, 2010 | 12:15 PM
HemiRam1566's Avatar
HemiRam1566
decarbon the intake and throttle body.. worked for my buddies truck.. used kleenflow intake kleen sprayed it in the TB and used a tooth brush to scrub it (very dirty) then started it up and sprayed it in the engine while keeping it running.. you should have seen the crap it was spitting out the tail pipe.. runs great now..
Old Sep 6, 2010 | 04:24 PM
InspectorVol
I forgot to mention that the code the truck gave out was p 0601. I think this is saying the computer is screwed up but it runs great except for the idle problem.
Old Sep 6, 2010 | 06:45 PM
tenntech's Avatar
tenntech
Remove the iac and clean it good, may require replacing. Some dodge's have idle problems with low battery voltage also. P0601 is internal controller (PCM) failure. You will definitely need a PCM to get the light off.
Old Sep 6, 2010 | 10:17 PM
InspectorVol
[quote=tenntech;2255237]Remove the iac and clean it good, may require replacing. Some dodge's have idle problems with low battery voltage also. P0601 is internal controller (PCM) failure. You will definitely need a PCM to get the light off.[
Does this mean a whole new computer? Will one from a junker work?
I have already replaced the part. Did not help.
Old Sep 7, 2010 | 12:28 PM
InspectorVol
Bump.
Old Sep 7, 2010 | 12:47 PM
That1guy's Avatar
That1guy
A junk yard would work but it would have to be optioned exactly like your truck I think.
Old Sep 10, 2010 | 10:34 PM
tenntech's Avatar
tenntech
I have already replaced the part. Did not help.[/QUOTE]
If you have a gray key(with skim), then I would not use a junkyard pcm. If you have a black key(w/o skim), you may be able to get by with a used controller.
Old Sep 11, 2010 | 08:17 AM
Flying Mullet's Avatar
Flying Mullet
You could try replacing the TPS and clearing the code to and see if it comes back. Mine was doing that a few weeks back but without the code, just needed a new TPS.
