Wont start
Old Sep 12, 2010 | 03:11 PM
Zeke90's Avatar
Zeke90
Default Wont start
Ok i have an 04 dodge 4.7 L and it wont start i car outside the other day and tried to start it and wouldnt crank. When i turned the key all i heard was a long buzzing or beeping noise its kinda hard 2 explain. I thought it might of been the battery but i put a new 1 on and still nothin what could it be??
Old Sep 12, 2010 | 05:10 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Just to be sure, when you say it will not crank, will the engine turn over at all or not all all? Have you verified you have spark on your plugs and they are wet from fuel? When was the last time it did run? Any noticeable issues around that time?
Old Sep 13, 2010 | 01:05 AM
Zeke90's Avatar
Zeke90
No it wont turn over at all and no there were no previous issuse with it always ran smooth, routine oil change made sure it was sound. And no sort of leaks lik oil and everything. I also checked to see if there was oil an d there was. i drove it Sat an it was fine lik normal and then on Sun i went outside to try and leave but that when it happened.
Old Sep 13, 2010 | 06:46 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
If the engine will not turn over at all (rotate internally) then it is either locked up, a bad starter, bad ignition switch or go check ALL of your fuses and especially fuse 23 I think which is the PCM fuse.
