ABS Warning Light
Old Sep 17, 2010 | 10:45 AM
FireFighter's Avatar
FireFighter
From: The old famed Gen3 Broken Valve Spring Thread - https://dodgeforum.com/forum/3rd-gen-ram-tech/237316
Default ABS Warning Light
I've had my ABS light up with a "ding" three times over the last month or so. Stays on until the truck is turned off then stays off after cranking it again. I dont seem to have any braking problems. I am also just driving, not braking when the light came on. Any ideas?
I did a search, wasn't too sucessful in finding anything.
Thanks all
Old Sep 17, 2010 | 10:50 AM
RedTruck-VA's Avatar
RedTruck-VA
Check the front sensor connector to make sure it is clean and tight.
Old Sep 17, 2010 | 03:11 PM
cwboyjohnny24's Avatar
cwboyjohnny24
Also, look to see if your ABS/speed sensor on the top of the rear end has any corrosion or the wires look bad.
Old Sep 18, 2010 | 04:47 PM
FireFighter
Cool, thanks guys. The connector under the hood next to bettery I assume? Yep, that's squeaky clean, looks brand new.
Ironically, my front left began a "rubbing, whirring" sound when brakes applied or not. Took the wheel off and looks like the pads are in need of replacement. So, about to go start all that. I'll take a look at the speed sensor. Appreciate it!
Old Sep 18, 2010 | 09:10 PM
RedTruck-VA
There is also a front wheel sensor that occassional will foul. Look it over carefully while doing the brakes. There seems to be a relationship between the to. Good luck...
Old Sep 19, 2010 | 12:09 PM
FireFighter
Ok, will do, thanks RedT...didn't know there was one there. Gotta wait til Monday now, brakes I wanted not in stock. ABS warning came on this morning on the way to church...when I accelerated...weird.
