A/C Need help FAST!!!!!
Old Sep 21, 2010 | 08:12 AM
srose6's Avatar
srose6
Exclamation .....Does No One have a solution to this problem?
is there not a solution to this problem? i really dont want to have to take the truck in if i do not have to. any advice would greatly help.
Old Sep 21, 2010 | 10:16 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
The resistor block for the fan inside the can for the dash vents is under the dash.
If you are talking about the AC condenser fan under the hood, if it is not blowing when you turn the AC on then I would get a meter and check for voltage at the fan. If not then check those fuses. If there is power and the fan motor isnt running then its time to replace the fan motor
Old Sep 21, 2010 | 10:36 AM
MongoDV8's Avatar
MongoDV8
Originally Posted by srose6
My 2008 Dodge Ram 1500, this morning my A/C was working fine and blowing cold air. i later this afternoon i went to the store and when i got back in the truck the blower would not even kick on at all. i popped the hood and the evaporator was frozen over.
Evaporator is located under the dash and I doubt you can see it through the engine compartment. Unless you are talking about the a/c lines going through the firewall.
If not then you mean the condensor like Weedahoe said. The condensor is located up front by the radiator. Does the condensor fan come on when you run the a/c ?
Old Sep 21, 2010 | 01:19 PM
srose6's Avatar
srose6
i was reading other posts and someone said tapping on the box under the glove compartment that has the blower more in it might help, and sure enough after i tapped on it everything started working again.. not sure what is going on.
Old Sep 21, 2010 | 03:21 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
You havent read all the posts because you missed mine where I was asking which fan you are talking about? LOL
See post #12
Old Sep 21, 2010 | 04:31 PM
srose6's Avatar
srose6
if i am having to tapped this to get it working again, does this mean that it is starting got go out on me? and should i go ahead and replace it? how much will this part cost me.
Old Sep 21, 2010 | 04:39 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I quit..........
Old Sep 22, 2010 | 01:35 AM
srose6's Avatar
srose6
Default Problem Fixed...
i fixed the problem. thanks for everyone's input and help they offered.
Old Sep 22, 2010 | 01:50 AM
Marx's Avatar
Marx
what was the problem???
Old Sep 22, 2010 | 01:55 AM
srose6's Avatar
srose6
blower motor was bad, replaced it...now no problems
