Windows wont roll up
Old Sep 20, 2010 | 09:20 PM
akinder09's Avatar
akinder09
Default Windows wont roll up
well i just got back from class and i rolled my windows down on the way home and now they wont go back up any of the 4 the back sliding one still works and everything else in the vehicle does
i have a 2008 dodge ram quad cab
anyone know whats going on
also i used my diablo to look for codes and i have none pulled
Old Sep 20, 2010 | 10:00 PM
dirtydog's Avatar
dirtydog
Moderate User
Maybe your master switch went bad..driverside switch. Water damage is #1 on those, but should still be warrantied. Sucks they are stuck down.
Old Sep 21, 2010 | 12:49 AM
akinder09's Avatar
akinder09
yeah i know i guess ill take it to the dealer tomorrow
Old Sep 21, 2010 | 10:35 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Be sure to let us know what you find out.
Old Sep 21, 2010 | 10:21 PM
akinder09's Avatar
akinder09
yeah they rolled up this morning but now wnt move anymore so i think its a bad connection im going to pull off the door panels and check the connections
Old Sep 21, 2010 | 10:46 PM
badblackram06's Avatar
badblackram06
You might can just check the window switch. It pops right out of the door panel. Mine has had troubles like yours. I cleaned the contacts and put in some dielectric grease and haven't had a problem since. and its been nearly 4 months where it gave me trouble almost everyday.
Old Sep 22, 2010 | 12:19 AM
akinder09's Avatar
akinder09
well none of the window switches work so i think it may be the relay under the dash not sure what to do with it i guess ill do some research first...did all of your window switches stop working or jst one?
