Y does throttle cut out at 4k rpm?
Old Sep 21, 2010 | 09:00 PM
lou911's Avatar
lou911
Default Y does throttle cut out at 4k rpm?
2004 ram 2500 hemi.........when rpms hit 4k, throttle cuts out, but not all the time. seems to do it only when warmed up. and does it in every gear including neutral and park. any help would be appreciated.
Old Sep 22, 2010 | 07:55 AM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Welcome to the site. There is a rev limiter at 4000 RPM while in neutral and park. I will move this thread to the third generation Ram section,
FF
Old Sep 22, 2010 | 09:12 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
As said above, it is the rev limiter. It is in place to keep you from damaging the engine although it can be bypassed with a tuner like Diablo or Superchips. A lot of guys move up the limiter to a higher number including myself.
Old Sep 23, 2010 | 10:05 PM
Dawizman's Avatar
Dawizman
My 2004 2500 hemi does this from time to time. I've never figured out what it is. I just turn the ignition off & start it up again, and it goes back to normal.
Old Sep 23, 2010 | 11:20 PM
irishcarbomb's Avatar
irishcarbomb
throttle position sensor?
Old Sep 24, 2010 | 03:56 AM
jeman022004's Avatar
jeman022004
I also experienced this once about 6-months back. I shut it off and started it back up and it went away. It was a pain in the rear when I was merging on the highway in DC!!!!
