Bulb Size
Old Sep 28, 2010 | 08:20 PM
akinder09's Avatar
akinder09
Default Bulb Size
I have a 2008 dodge ram 1500 with these halos
http://www.k2motor.com/4lhpram06jmks.html ....ive seen some people on here with those so im sure someone will know.. I need to know what size bulb my hi and low beams take? and i want the sylvania silverstars those are the brightest halogens rite?....also how do i change the bulb does the headlight glass come off or do i need to pull the whole thing and take it apart to get to them....
Old Sep 29, 2010 | 08:55 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
You can always email and ask the seller but I think they are either H1's or H11's. To change the bulb you can either remove the entire headlight itself to get to the back side of it or go under the truck to get to the back side of the housing.
Old Sep 29, 2010 | 04:28 PM
eric41191's Avatar
eric41191
It is an h1. It's 12v 55 watt I think. It's a wierd looking bulb with a single connector.
Old Sep 29, 2010 | 10:54 PM
akinder09's Avatar
akinder09
both the hi and low beams are h1 i know the hi beam is really small and flat i cant really see the low beam
