Will I need Wheel Spacers
Old Oct 9, 2010 | 03:28 PM
Matt99's Avatar
Matt99
They are federals...supposedly same as the Toyo MT, they are alright but not my first choice...I had a hard time getting 35s for a 20 and didnt wanna wait another two months and these were the first to come in...still $1200
Old Oct 9, 2010 | 03:53 PM
dirtydog's Avatar
dirtydog
Moderate User
Originally Posted by Paratrooper
duno, well regardless of wheels, the rotor studs extended past the wheel spacer so it wouldn't mater what wheel i used i would have had to trim a tiny bit off the studs. unless my spacers weren't 1.5" never took a tape measure to it but they sure did look it.... dog dammit if i have to take a pic and prove it i will lol
This is incorrect. It Definately matters what wheel you have. The stock 17" wheels you will need to cut the studs as the backside is flat from what i have been told.
The factory 20" wheels have recessed notches on the backside that will allow a portion of the studs to protrude into, so no cutting will be needed depending on how far they are sticking out??.
There is a good 1/4" of recess on the backside of the wheels, so that means if there's up to 1/4" of lugs that stick out past the spacers, the wheels can be mounted with no interference.
You just dont want the lugs contacting the wheels because the wheel may not sit flush against the spacer and can cause problem going down the road.
Old Oct 11, 2010 | 08:24 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
yeah my lugs were about 18 to 1/4 exposed maybe its a year thing either way if u dont its good if u do its easy as hell just get a dremal tool
Even with a dremel and a diamond circular blade it would take forever. You would be better with a sawzall.
Old Oct 11, 2010 | 12:30 PM
dirtydog's Avatar
dirtydog
Moderate User
A sawzall?..lol
I know a sawzall is a universal tool, but c'mon man. That's hilarious.
I could see the OP taking a sawsall to his lugs and the blade bouncing all over the place.
I'd agree a dremel would take quite a while; however, I think an air grinder or even an electric grinder would be much more feasible. That's what I used on my mustang studs when i first put on spacers before i got new wheels. The only thing I did not like about grinding down the studs, was the lug nuts were a PIA to thread on everytime I took the darn wheels off. I would be very weary of a garage stripping the threads because of that. Something you would want to warn them about so they are aware of the possibility.
Old Oct 11, 2010 | 02:39 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Ok fine. use a torch then!!
Old Oct 11, 2010 | 04:35 PM
Matt99's Avatar
Matt99
I think Weed is a sawzall guy, kind of how some people say a dremel does everything and others use tape for everything
i have seen numerous threads where he advised on a sawzall lol
Old Oct 11, 2010 | 04:46 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Hey, I used it on my frame end rails when doing the bumper mounts for my body lift. I tried using an cutting disc on an air tool and it took too long. A good saw blade did it in less than 5 mins though.
Old Oct 11, 2010 | 04:48 PM
Matt99's Avatar
Matt99
a sawzall did mine on my body lift like butter
