Shaking and knocking from 4.7...
Old Oct 16, 2010 | 02:02 AM
JonnyBlaze420's Avatar
JonnyBlaze420
Originally Posted by outcast
my 4.7 blow up at 80,000 air filter not in box right fried the pistons took it apart and the timing chain was loose as hell, only had the truck for 3,000 miles bought it from my dad and he never drove it hard it cost me 4,000 dallors to rebuild and bore, then the tranny went out 5,000 miles later talk about bad luck
Are you serious???? MAybe I shouldnt put my cold air intake on then...Damn.
Old Oct 16, 2010 | 09:05 AM
FishArNekEd's Avatar
FishArNekEd
the water pump in the wifes 4.7 was loose it jangled around in iis housing, made the fan cluth go out. but after i replaced them, truck is fine. my tranny has gone out twice in my 4.7 (wish i had the 6 speed like the wife got) good luck
i got a k&n full intake, it has been great to me. no way for the filter really to jame up the flow, i guess it could fall off but i check it by open hood and look, easy. my ol ladys fell off, and she ran it over, so i put a wannabe K&N filter on the tube and it has been fine also.
Old Oct 20, 2010 | 05:08 PM
outcast's Avatar
outcast
yeah i ran a cheap fram filter and the foam on the side ripped out put in a k&n stock replacment filter has a metal ring arond it still runnin good
Old Oct 20, 2010 | 05:53 PM
9511234's Avatar
9511234
Lol -- I was going to say -- got a bit of a lead foot if you were running it 4500 and leaving it there. lol.
Old Oct 22, 2010 | 07:44 PM
truegent81's Avatar
truegent81
i was about to say...4500rpms??? damn! cruising at 70mph i'm at 1800-2000rpms...i've never gone over 2500rpms
Old Jan 17, 2011 | 11:18 PM
woodchip's Avatar
woodchip
So now two months later I have water coming up the breather tube into the air intake.keeps freezing in the idle air cotrol valve and prevents the truck from idling.do you suppose that new head gasket is leaking?
Makes sense seeing as it was a dealer repair.4000 dollars so the truck still won't run.
Old Jan 18, 2011 | 10:16 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
There is no way a leaking head gasket can leak water and come up through the engine, out the intake, backwards through the TB and into the air intake system. That just wont happen.
Old Jan 19, 2011 | 08:25 PM
woodchip's Avatar
woodchip
It's moisture coming from the tubes off the tops of the two head covers.Sometimes alot.where is it coming from?
Old Jan 22, 2011 | 01:38 AM
wolf22m's Avatar
wolf22m
Just put a small filter on that line coming from the head. I added a catch can on mine so anything coming in would get trapped and not go into the intake. My truck runs great without it connected to the intake.
Old Jan 22, 2011 | 07:58 AM
AIR_RAM's Avatar
AIR_RAM
If you want that moisture to go away... Drive it harder get the engine hotter and it will evaporate... Normally the moisture in the oil filler tube is found on engines that are typically driven short distances for short Periods of time. This allows the condinsation to build up... If the engine gets warm enough, you can burn all the condinsation out... My engine has never had this buildup but I know plenty of people who have.... Heat will help prevent it.
