towing question
Old Oct 12, 2010 | 03:36 PM
mexico's Avatar
mexico
Default towing question
hey guys. so my truck has 125k on the clock. its a 2wd Hemi. do you think it would be unwise to tow my gf's 99' Malibu from Michigan to Virginia? does something need to be done to the truck first? should I check something?
Old Oct 12, 2010 | 04:35 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Just check everything as you normally would like tire pressure, fluid levels, ECT. Do you feel "good" about your truck? Do YOU think it will make it and not give any issues? No one knows it better than you do.
Old Oct 13, 2010 | 07:47 AM
emcanurse's Avatar
emcanurse
Weed is right....if you have a properly maintained truck , it should be no problem. I would just make sure that that trailer is also in good shape. I personally like trailers with electric brakes and always use a weight distributer whenever possible ( makes the tow so much better). I know that the Uhaul use surge brakes and are harfer om your own brakes and require longer braking distances. Good luck
Old Oct 13, 2010 | 11:25 PM
mexico's Avatar
mexico
well im pretty sure that the tranny fluid has never been replaced but my grampa(mechanic) told me not to at this point because of how many miles are on it... as long as the fluid is good color which it is
Old Oct 13, 2010 | 11:30 PM
freestyledude's Avatar
freestyledude
Newer ATF cannot be judged by color (or so says my service manual)
I doesn't hurt to drop the pan and replace the filters especially before a big trip
Old Oct 14, 2010 | 05:47 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Hey, Ive got some food in the fridge that is kinda old. Should I keep it and use it for dinner tonight or throw it out?
Get our point?
Change the fluids. ALL of them including the rear diff also.
Old Oct 14, 2010 | 08:16 AM
HammerZ71's Avatar
HammerZ71
The not changing of the tranny fluid after a certain point was an old school thing that has been disproven over and over in recent years. Change the tranny fluid...
Old Oct 15, 2010 | 12:29 AM
bgbluram2's Avatar
bgbluram2
Yep, Not changing the fluid is a bad idea. Over time it looses viscosity which means that it doesn't have the lubrication characteristics that it once had. Replacing the fluids will do nothing but improve lubrication in the tranny which also helps keep it cool which will help while towing. Check/change fluids that need to be changed, flush the cooling system if it hasnt been done, check tire pressures, etc.
