trailer wiring problem
Old Oct 14, 2010 | 01:30 AM
gordie580's Avatar
gordie580
Default trailer wiring problem
So i went to hook up to a trailer using the 4 pin connector. Well, to find out the medal has rusted out and there is none inside to make a connection. So i used the 7 pin with an adapter. So i need to replace the 4 pin, so there a plug someplace the factory puts in or do i have to cut the old 4 prong wires and just re-wire the new end.
Thanks
Old Oct 14, 2010 | 05:25 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
You could likely go to someplace like Autozone or Walmart or TSC and find/buy those male/female harnesses
