Grinding in Torque Converter?
Old Oct 20, 2010 | 11:10 PM
freestyledude's Avatar
freestyledude
Didn't touch the bearings, but when I turned the crank over by hand it didn't make a sound, now when I turn it by hand I can hear it. I heard it instantly when I started the motor
Old Oct 21, 2010 | 01:19 AM
traker1001's Avatar
traker1001
What exactly did you do to the engine? When you say you "Rebuilt it" Did you actually pull it out of the truck, Or just pull the heads and do what you could with it in the truck?
Old Oct 21, 2010 | 02:20 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Yeah because when i say rebuild I mean completely broken down, cleaned, machined and reassembled with new parts. If you are spinning the crank by hand and hearing it and even more when the engine is running then STOP NOW while you are ahead and at least check the oil for metal particles and drop the oil pan to inspect.
Old Oct 21, 2010 | 07:50 PM
freestyledude
I pulled the motor, stripped it down to a short block. (crank, cam left in) Replaced one connecting rod that broke, had the block inspected. Turned over fine with no noise.
Today I noticed that it changes pitch when I put the brakes on, whether its in park, D, etc. What could that be?
Old Oct 21, 2010 | 09:29 PM
PhotogTom's Avatar
PhotogTom
Starting to sound more like an alternater issue. Not certain, but you do change the electrical draw a little when you put the brakes on, due to the additional lights that are lit. Try turning on the lights and listen to what happens.
Old Oct 22, 2010 | 12:55 AM
freestyledude
The reason the motor was rebuilt was hydrolock. Could a bit of water spray fry the alternator?
Old Oct 22, 2010 | 04:30 AM
RedTruck-VA's Avatar
RedTruck-VA
Fried maybe the wrong term, how about the bearings are shot. The alternater should not be hard to turn. Like I said before, if you think it is the problem then either listen to it using a stethoscope or remove the belt and start the engine and see if the noise is still there. You will probably catch flak for not doing a complete job on the bottom. Hopefully the small amount of effort/$$ you saved won't come back to bite you. Good luck..
Old Oct 22, 2010 | 05:31 PM
freestyledude
If I screwed up and put one of the rods on backwards could that be it? Had them all labeled with # and direction but who knows
Old Oct 23, 2010 | 05:51 AM
RedTruck-VA
The pistons are marked on the piston pin bore
surface with an raised “F” or arrow on top of piston
indicating installation position. This mark must be
pointing toward the front of engine on both cylinder
banks. The connecting rod oil slinger slot faces the
front of the engine.
Assuming you took note of these indicators when installing the piston/rod you should know if everyting was assembled correctly. But since you asked, I'm thinking perhaps you didn't. Good luck.
Old Oct 23, 2010 | 01:58 PM
freestyledude
Yep I did check with those markings.
But I did just remember, the torque converter got dropped on the concrete. Could this wreck the torque converter? Newbie questions I know... did a lot of research but apparently not enough
Popped off the belt and the noise is still there. For some reason the alternator spins freely now?
