Best spot for e-fan therm. switch?
Old Oct 20, 2010 | 03:47 PM
sinus19's Avatar
sinus19
Default Best spot for e-fan therm. switch?
whats the best spot for my e-fan's thermal switch? i have tried sticking it through/around/next to my radiator, but no bueno. it is a preset 180 switch.
Old Oct 20, 2010 | 07:19 PM
MikeHTally's Avatar
MikeHTally
Switch or sensor? The sensor needs to be very near the top radiator hose. A switch can be anywhere.
Here's mine: the thin silver wire runs down to the sensor poked through the radiator near the top hose.
Old Oct 20, 2010 | 07:32 PM
sinus19's Avatar
sinus19
my bad! i meant sensor.
Old Oct 20, 2010 | 11:03 PM
sinus19's Avatar
sinus19
i tried taping it down to th radiator hose but nothing either. hmmmmmm. it seems as if it needs to be in contact with the coolant???
Old Oct 20, 2010 | 11:11 PM
freestyledude's Avatar
freestyledude
You mean the probe sensor? you push it through the radiator fins, gently
Old Oct 21, 2010 | 09:27 AM
sinus19's Avatar
sinus19
yea, ive tried that. and it dont work?
Old Oct 21, 2010 | 02:13 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
It will slide through the fins. I have mine about 2" to the side of my upper rad hose outlet/inlet and 2" below it. It helps it you get a small screwdriver or awl and open the fins and then grease the probe to slide in place. You know that works right??
