2003 1500 ram hemi truck ...rear brakes
Old Oct 22, 2010 | 12:39 PM
tav's Avatar
tav
Default 2003 1500 ram hemi truck ...rear brakes
need some info on rear brakes, now i know they are rotors with pads and i can take them off no problem and i there is a parking brake system to it.
now if i cant get the rotor off how do i collapes the shoes someone said theres a star wheel you turn ?
is the shoe system when taking off the same traditional type as every other shoes (drum style) with big spring of it it different on this truck ?
Old Oct 22, 2010 | 01:44 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
You have rotors and pads all the way around the truck. You can use several things to compress the caliper pistons back in place. I use a big C clamp
Old Oct 22, 2010 | 02:18 PM
tav's Avatar
tav
weed,i do understand the rotor part i do the fronts alls the time and use a c clamp to compress the calipers also, my question is in the parking brake shoes...if i cant get the rotors off cuz shoes are opened to far an hitting the inside of the rotor how do i close the shoes to make taking off the rotor ezer to side off.
Old Oct 22, 2010 | 02:32 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Cant help that one....Ive never taken parking brakes off.
Old Oct 22, 2010 | 02:37 PM
dodgetimes2's Avatar
dodgetimes2
I believe the proper way is to use the starwheel adjuster to back them off. However, I had the same problem and ended up just squiting some WD-40 on the back of the rotors and then banging on the back of them with a rubber mallet. Just a few squirts near the parking brake shoes and the rotor slipped right off. You could also try driving with the parking brake on slighty and see if that loosens their grip.
