dash lights go dark in spots randomly
So my 02 is doing something weird. I wouldnt be confused except that its on and off. First the 11 o'clock position on the tachometer went dark and stayed that way. So I figured a blown bulb. Next the oil light went out a few months later. It randomly we be dim like a dead bulb then go dark again. After a month it now is fine and hasnt got dark again. So now a few months later the 11 o'clock of the speedo went dark and stayed dark. Whats going on?
The bulbs in the cluster cannot be changed. You would need a whole new cluster. Smart idea right?
i would check the conectors in the back of your cluster to make sure they are not loose and have a good connection. I can't think of a specific reason why they would do what they are doing though? Almost sounds like there's not enough current being fed to their source which seems like a loose connector or maybe it the connectors have corrosion?
Trending Topics
The loose connection does make sense. I just had the thing off this summer to replace me heater core and the cluster laid in the garage for a few weeks before reinstalling....
So are they bulbs or leds? Is it common to burn out? I really dont want a new cluster. If anything I want a 2500 hemi cluster with number instead of stupid high low crap, but i know a dealer wont do that.
