Engine stalls at idle and low RPMs NEED HELP FAST
Old Nov 12, 2010 | 06:59 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
On at 04, the IAC is inside the throttle body I think. It is replaced as a unit (TB)
Old Nov 15, 2010 | 08:36 AM
cbankr22's Avatar
cbankr22
I had someone do it so I am not sure. In my book it looks like it is right under the TPS.
And btw, this didnt fix the problem. As soon as I went out around town for a few hours and sat in some traffic we were back to the same ole issue...
Any thoughts??
Old Nov 15, 2010 | 05:19 PM
RedTruck-VA's Avatar
RedTruck-VA
Originally Posted by jfreeman74
This is for a 2004 Ram 5.7L. I have to put my foot on the gas to start it and keep my foot on the gas. I thought it was a clogged CAT. I had the engine codes checked and it came back with "multiple misfires and open circuit on injector 8" so I replaced injector 8. That didn't help. Checked codes again and it gave O2 sensor before the CAT on the drivers side. I popped the exhaust loose from the exhaust manifold and it fired up okay. I replaced the CAT on the drivers side and it still didn't help. What else could it be? This is driving me crazy and I have to get it running by Saturday. Any help would be appreciated.
OP has a 5.7L engine, he got hijacked by 4.7L crowd. Have you pulled the VC to check the springs? I understand early 04's also have spring problems.
