Having Brake Issues
Old Oct 28, 2010 | 04:44 PM
Jlh06's Avatar
Jlh06
Default Having Brake Issues
Hey everyone. I have an 06 Ram bighorn that I recently replaced front brakes and rotors on. I am now have problems with "vibration" in the streeing wheel when every I hit the brakes. It did start right away though I have had the new brakes since Aug. but start this issue about a week or two ago. Does anyone have an advice for what might be causing this??? Thank you
Jeff heiser
Old Oct 28, 2010 | 05:02 PM
Big_Wheel's Avatar
Big_Wheel
warped rotor or maybe a loose bolt on your caliper take the wheels off and inspect
Old Oct 29, 2010 | 07:39 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
yeah, usually it is warped rotors. Did you re-use your OEMs and if so did you have them turned or cut?
Old Oct 29, 2010 | 01:20 PM
Rich 2500's Avatar
Rich 2500
Do you feel anything in the brake peddle?
Is it a high frequency vibration on a pulsing back and forth?
Does it still do it if you hit the brakes hard?
