Stutter shift
Old Oct 30, 2010 | 04:19 PM
teamgraphx@aol.com.'s Avatar
teamgraphx@aol.com.
Default Stutter shift
04 ram hemi 1500 4x4 165,000 mi.. the trans seemes to buck or stutter to shift when going up*hill*in OD before down shifting. I have to hit the pedal or take it out of cruise to*make it shift*
Any help?
Old Oct 30, 2010 | 05:09 PM
dirtydog's Avatar
dirtydog
Moderate User
When is the last time you had your transmission filters changed and fluid flushed? They should both be done every 60kmi, but the filters definately every 100kmi an sooner if you do city driving.
Old Oct 30, 2010 | 06:38 PM
teamgraphx@aol.com.
just had the trans serviced. but may been a while since I can be sure the filter was changed
Old Oct 30, 2010 | 10:31 PM
teamgraphx@aol.com.
this has been an issue for a while and it seems to have got worse. I had the superchips tuner set to 91 but now its retuned to stock. still does it, not as bad but still does it
Old Nov 2, 2010 | 05:19 PM
teamgraphx@aol.com.
So any ideas of what's up with this trans. The dealer can't diagnose it without trouble code
Old Nov 2, 2010 | 05:28 PM
dirtydog's Avatar
dirtydog
Moderate User
Well theree are 2 filters inside the transmission pan. It would be a good idea to change those out even if it doesn't fix your problem. That is where I would start!
Almost sounds like the filters are semi-clogged and not allowing enough fluid to build the pressurequick enough. using the electronic controls overrides certain gears and can help in shifting in the O/D gears.
