New to the 3rd gens
Old Nov 5, 2010 | 08:23 AM
Ram_King's Avatar
Ram_King
Question New to the 3rd gens
i have just purchased a 2005 ram 1500 with the 4.7l v8, it has 155k, and i was just bringing up some of the problems it has to see if its an easy fix or if i should have the dealership fix it, for one the fan speeds 1 and 3 do not work. any ideas? and while going down the highway it makes a grinding noise when it shifts out of overdrive. any ideas? thanks for the help
Old Nov 5, 2010 | 08:54 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
As for the fan speeds, it is either in the control switch **** on the AC controls but more likely the fan resistor block which reduces voltage to control the 4 speeds. The block in under the bash. There are a few threads on this and you can download the service manual for your truck in my signature links listed below.
As for the grinding noise IDK but since you are a new owner and do not know the exact maintenance of this truck, it would be a good idea to replace the trans oil as well as all other fluids.
Welcome to the site BTW
Old Nov 5, 2010 | 09:47 AM
2005cobrakiller's Avatar
2005cobrakiller
and dont just flush the trans you might not like what happens.... pull the pan off and drain it traditionally.... I know the 5.7 trans has 2 filters and when a simple trans flush is performed it moves them out of place...
