can bus fuse blowing
Old Nov 6, 2010 | 04:55 PM
45dodge's Avatar
45dodge
Default can bus fuse blowing
have a 07 dodge3/4 ton. the can fuse keeps blowing have no dash lights or courtsy lights. i went threw the charts from all data and the test are saying replace cluster is there anything i might be missing i unplug the cluster and the fuse does not blow. i use a power probe i can turn all the lights on. not sure what else it can be i replace the headlight switch just in case. did not work lost on this one
Old Nov 6, 2010 | 07:36 PM
AF_HEMI's Avatar
AF_HEMI
so when the cluster is hooked up, the fuse blows, but when you remove the cluster it doesnt blow? sounds like you found your problem. must be a short in the cluster.
Old Nov 6, 2010 | 07:53 PM
rickof08's Avatar
rickof08
I had the same issue, ended up being a wire that leads behind the radio. It was rubbed down to the wire and touching metal. I taped it up, moved it, and never had the problem again. Also, it ended up blowing some of my dash lights
Old Nov 8, 2010 | 12:16 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I agree with AF HEMI, if you hare blowing fuses but remove the IC and nothing blows, well, thats sounds pretty clear and simple to me
