05 RAM HID problems
Old Nov 12, 2010 | 02:31 PM
Sika05's Avatar
Sika05
Default 05 RAM HID problems
I have aftermarket Halo projector headlights in my truck the High beam and low beam are seperate in the assembly and use an H1 style bulb when I put the HIDs in and used the relay harness they would alternate turning on for only a sec. and then nothing for a min then repeat. So I hooked them up without the harness and they both worked but after a while they would start to flicker or the beam had a wiggle motion in it. does anyone know the right configuration to fix this.
Old Nov 12, 2010 | 02:49 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
This is sticked at the top of this section
Got HID Problems? Check in here...
