eed to know tranny fluid amount of ATF+4 I need to buy to refill my 04 ram 4x4 with a
Need to know tranny fluid amount of ATF+4 I need to buy to refill my 04 ram 4x4 with a 5 speed auto tranny.
How do I know if I have the O-haul option?
I do have the button on the column shifter, but it doesn't say tow/haul.
Is that O-haul option?
Here's my buildsheet but I don't see O-haul option in the sheet.
Need some help. I just want to change my tranny filter and fluid.
If I have the O-haul option do I need to buy another 14-16 quarts of ATF+4 to refill that separately?
Build sheet below.
Thanks!
Sales Code Description
*M9 Cloth 40/20/40 Prem Bench Seat
-DV Dark Slate Gray
AGG Sport Group
AHC Trailer Tow Group
AJB Security Group
APAS Monotone Paint
A85P 5.7L ENG (EZA)/5SPD A/T 5-45RFE(DGQ)
BAZS 136 Amp Alternator
BCVP 700 Amp Maintenance Free Battery
BRT Anti-Lock 4-Wheel Disc Brakes
CBEP 40/20/40 Split Bench Seat
CGDS Front Height Adjust Shoulder Belts
CG1S Next Gen Multistage Front Air Bags**
CKES Front Seat Area Carpet
CLAS Front Floor Mats
CSPS Passenger Assist Handle
CSXP Rear 60/40 Split Folding Seat
CUES Rear Underseat Compartment Storage
CUSS Overhead Console w/Trip Computer
CVHP Front Center Seat Cushion Storage
DGES All 5-Speed Automatic Transmissions
DGQ 5-Spd Automatic 545RFE Transmission
DHAP Lock-Up Torque Converter
DHES Man Shift-on-the-Fly Transfer Case
DJMS 205MM HD Front Axle
DMH 3.92 Rear Axle Ratio
DRBS Corporate 9.25 LD Rear Axle
DSA Anti-Spin Differential Rear Axle
EAGC All Gas Engine
EZA 5.7L V8 HEMI Engine
GACS Tinted Glass Windows
GFD Rear Sliding Window
GNAS Rear View Day/Night Mirror
GNMS Passenger Side Sun Visor w/Mirror
GTSS Power Heated Mirrors, Fold-Away
GVBC All Vehicles W/Power Mirrors
GXMS Remote Keyless Entry
GXXP Sentry Key Theft Deterrent System
HAAS Air Conditioning
HGBS Dash Liner Insulation
HGFS Floor Tunnel Insulation
I23S Route 23 - CSX, Jessup, MD
JAYS Instrument Cluster w/Tach
JCBS 120 MPH Primary Speedometer
JHAS Var Intermittent Windshield Wipers
JJAS Cigar Lighter
JJBS Dual Note Electric Horns
JJJS 12V Auxiliary Power Outlet
JPBS Power Locks
JPDS Power Windows, Driver One-Touch
JRDP Power Driver Seat
JTHP Power 6-Way Driver Seat
K4RP STRIPE/BADGE/MOLDING/COLOR
LBCS Glove Box Lamp
LMAS Halogen Headlamps
LNJP Fog Lamps
LPES Cargo Lamp
LSAP Security Alarm
MBPP Body Color Front Bumper
MBQP Body Color Rear Bumper w/Step Pads
MDAS Front License Plate Bracket
MFNP Body Color Grille
MTDS SLT Badge
MURS Dodge Badge
MUSS 4X4 Badge
MWDS Removable Tailgate w/Caliper Latches
MXBS Front Air Dam
MXCS Front Bumper Sight Shields
NAS 50 State Emissions
NBEP U.S. Emissions w/OBD 1
NBKP EVAP Control System
NFWS 26 Gallon Fuel Tank
NHBP Auxiliary Transmission Oil Cooler
NHMS Speed Control
NHNP Electronically Controlled Throttle
NMCP Heavy Duty Engine Cooling
NZDP Next Generation Engine Controller
PR4A Flame Red Clear Coat
QR4S Flame Red Clear Coat
RAAC All Radio Equipped Vehicles
RAZ AM/FM Cassette Compact Disc Radio
RCKP Infinity Speakers
RDDP Fixed Long Mast Antenna
RDZ Steering Wheel Mounted Audio Ctrls
SBAS Power Rack and Pinion Steering
SCV Leather Wrapped Steering Wheel
SFBS Front Heavy Duty Shock Absorbers
SGBS Rear Heavy Duty Shock Absorbers
SHAS Front Stabilizer Bar
SUAS Tilt Steering Column
TBBS Full Size Spare Tire
TBMS Tire Carrier Winch
TTJP P275/60R20 BSW All Season Tires
TZAP Goodyear Brand Tires
WGAP 20" Steel Spare Wheel
WLZC All Aluminum Wheels
WMJP Center Hub
WPG 20X9.0 Aluminum Chrome Clad Wheels
XAP Power Adjustable Pedals
XBSS Pickup Box
XFHP Class IV Receiver Hitch
XFKP 7 Pin Wiring Harness
XFUS Trailer Tow w/4-Pin Connector Wiring
YAAS Build To U.S. Mkt. Specifications
ZBSP Spring - Left Rear
ZCFP Spring - Left Front
ZPSP Spring - Right Rear
ZREP Spring - Right Front
Z6CS GVW/Payload Rating
2TGA Customer Preferred Package 2TG
26G Customer Preferred Package 26G
5I4S Four Wheel Drive (4WD)/(4X4)
5ZES 6 FT. Cargo Box
5ZKS Quad Cab
5ZLS 1500 Series
6F8 Paint Order Code
Build sheet below.
Thanks!
-DV Dark Slate Gray
AGG Sport Group
AJB Security Group
APAS Monotone Paint
EAGC All Gas Engine
JJAS Cigar Lighter
JPBS Power Locks
LBCS Glove Box Lamp
LNJP Fog Lamps
LPES Cargo Lamp
LSAP Security Alarm
MTDS SLT Badge
MURS Dodge Badge
MUSS 4X4 Badge
MXBS Front Air Dam
NHMS Speed Control
WMJP Center Hub
XBSS Pickup Box
5ZKS Quad Cab
5ZLS 1500 Series
The button the end of the shifter is Tow/Haul. All trucks have them now. As for the pan change, 6-7 qrts. But if you want to change the entire trans then 17.
This is the link that gets passed around for filter and fluid changes
http://www.60ateight.com/DodgeRam/
I do suggest buying all new trans bolts and be careful when putting them in. Replace them so the heads do snap off and be careful when locking them down so you dont strip the trans threads
Also look into adding in a trans pan drain bolt while you have it out and down.
I suspect his button is O/D off for an '04. My drop 'n' drain took seven quarts. Don't forget the filters. The spin-on is the same for 4x4 and 4x2, but the flat filter is different. And be careful with the pan bolts.
