Blend Door Fix Question
Well, I apparently have the blend door issue, as the passenger side vents work fine but the driver’s side, not so well. My question is does anyone know if Dodge has actually come up with a solution? Or, after I get it fixed, am I going to have the same problem in another 4 years?
Check this place out, a little more expensive but will last a lot longer.
http://www.heatertreater.net/Ram%2002-08%20Listing.html
