P1521
Just recently changed the oil using castrol 5W-20 that is required for the hemi with MDS. The other day I plugged the superchips in and just thought to check if any codes were coming up and a P1521 (Incorrect Engine Oil Type) came up. Anybody know anything else about this. It really confused me because I just changed the oil myself. Anyway thanks guys
I found this on a Hemi Charger forum-- hope it helps...
P1521–INCORRECT ENGINE OIL TYPE•When Monitored: Engine Running.
•Set Condition: Using the oil pressure, oil temperature and other vital engine inputs the PCM can determine the engine oil viscosity. Incorrect viscosity will effect the operation of the MDS by delaying cylinder activation .
Possible Causes INCORRECT ENGINE OIL TYPE ENGINE OIL CONTAMINATION ENGINE OIL
Always perform the Pre-Diagnostic Troubleshooting procedure before proceeding.
Diagnostic Test
1. ACTIVE DTC
NOTE: Review the customers oil change history. Ensure the customers is using the correct engine oil viscosity. If the incorrect oil is being used, change the oil, using the correct engine oil viscosity.
Ignition on, engine off.
With the scan tool, read DTCs.
Is the DTC active at this time?
Yes•Go to 2
No•Test Complete.
2. ENGINE OIL
NOTE: If set along with P1521, repair any engine oil pressure or temperature DTCs first before continuing.
The following conditions must be checked.•OEM recommended oil viscosity is being used.
•Customer is following the oil change schedule.
•Check the engine oil for contamination. (i.e., fuel and/or engine coolant)
•Internal engine condition that may effect oil pressure.
Were any of the above conditions found?
Yes•Repair as necessary.
•Perform the POWERTRAIN VERIFICATION TEST.
No•Change the engine oil using the correct oil viscosity.
Diagnostic Test
1. ACTIVE DTC
Yes•Go to 2
No•Test Complete.
2. ENGINE OIL
