2004 quad cab 5.7 4x4
Old Nov 27, 2010 | 04:17 PM
Backwoods's Avatar
Backwoods
Default 2004 quad cab 5.7 4x4
Hey guys, I'm having an issue with the electronic throttle control on my 2004 quad cab hemi. The light comes on when I step on the brake and it feels like it is still trying to pull forward, but then goes back out as soon as i get back on the accelerator. It started on my way home a week ago when the pedal dropped to the floor and the truck attempted to accelerate without my input. I put it in neutral and pulled off to the side...while in neutral the throttle was still open causing it to rev up on its own accord. I turned the truck off for a couple of minutes and turned it back on and it hasnt tried to accelerate without me again but now the light comes on every time I come to a stop and it feels like its trying to pull forward until it comes to a complete stop ( it just goes back to regualar idle after that). I'm at a loss here guys. any Idea what could be wrong?
Old Nov 27, 2010 | 05:27 PM
freestyledude's Avatar
freestyledude
Is the light a red lightning bolt? That would point towards the throttle body or the electronics associated with it
Old Nov 27, 2010 | 05:34 PM
Backwoods's Avatar
Backwoods
yes it is the etc light with the lightning bolt... also its not throwing a code I had just cleaned the egr valve about a week before this occured...
Old Nov 28, 2010 | 05:04 AM
abarmby's Avatar
abarmby
Have you taken off the TB and given it a clean?
A lot of tar like build up can occur on the back side of the TB blade.
I wonder if you have this and it's causing the blade of the TB to stick???
Worth a look and theres amore than a few posts on this board showing you how to do it.
Worth a search and a try?
Al.
