Sunroof Drain Tube ID ?
My Wife just called me and said the A pillar is leaking water. I know it could be either the screws for the door seal or a cracked / plugged sunroof drain tube.
I'm going to pull the A pillar trim down to look at the tubes when I RTV the door seal screws. So I thought I would get some tubing (rubber or vinyl) just in case its a cracked tube.
I looked up the P/N but the description does not give any size
So does anyone know the ID size of the tubes ?
And how many feet of tube should I get?
55276954AA, TUBE, Sunroof Drain, Rear
55276952AA, TUBE, Sunroof Drain, FrontSo does anyone know the ID size of the tubes ?
