5.9L trouble
Old Dec 5, 2010 | 01:12 PM
dpgpaving's Avatar
dpgpaving
Default 5.9L trouble
i have a 2002 ram 1500 5.9L, a few times when i start teh truck i would get a check engire light, code 340, (camshaft position sensor malfunction and code 1391)and after fueling up i couldnt get the truck running. after a little while it would fire right up and be fine. well recently i fueled up and it wouldnt start, at all. i can hear the fuel pump kick on. i changed the crankshaft position sensor and the coil. still nothing. I had a good camshaft position sensor (good when removed)that i replaced when i replaced the entire distributor because thats the error code i got 340. I dont know where to look next. a friend wants to put a scope on it to look at teh flywheel but he says he's never heard of the flywheel shattering without you being able to hear something being knocked around. any help would be greatly appreciated. Thanks
Old Dec 5, 2010 | 02:40 PM
michael davis's Avatar
michael davis
Lightbulb 5.9L wont start after fueling!
I would check the oil pressure sending unit i think on some models if the pressure drops below a specified amount the truck wont start, just a thought, However i also think that this would give an error code and set the ck enjine light. did you check spark when cranking in the no start situation?Whats your fuel pressure? Vaporlock? was it hot at the time. ethanol will cause a hard or no start, when temp is hi, ie summer, running the heck out of it. crank angle sensor,
Old Dec 5, 2010 | 06:32 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Welcome to the site. I will move this thread to the third generation Ram section,
FF
Old Dec 5, 2010 | 08:16 PM
brettj2408's Avatar
brettj2408
there are many things you can do.
you sure its notched in the right place on the distributor?
you can remove it back out and check if you have power and ground.
your P0340 code is telling you your ECM is not recieving the signal from the the CMP sensor
Old Dec 9, 2010 | 08:27 PM
dpgpaving's Avatar
dpgpaving
Default update
i sent the truck to a shop a friend works at and they ended up grinding down the bell housing so that the crankshaft pos. sensor made good contact. runs like a top now. $300 fix includes everything.
