fuse left taillight keeps popping
Old Dec 6, 2010 | 12:10 PM
sloopkogel's Avatar
sloopkogel
Default fuse left taillight keeps popping
Hi people,
i got a problem!!
for now reason my left tail light fuse seems to have a live of its own,
i change the fuse, end bring on the dimlights, all seems to be fine, but as soon as i start the engine, the fuse pops, sometimes it pops with only the dim lights on, with no engine running, and when i turn on the beems, the fuse pops, with no engine running.
sometimes i can put the lights on, nothing happens, and the will only pop when i start..
sometimes i change the fuse, turn on the dimlights and the pop..
anybody had a simular problem?
Old Dec 6, 2010 | 12:15 PM
sloopkogel's Avatar
sloopkogel
could it be that the front parkinglights are connected and the might couse the problem?
it seems that there is water in the lights, and the are also not working..
Old Dec 6, 2010 | 12:19 PM
sloopkogel's Avatar
sloopkogel
Sorry, my name is Rick i am a self employed welder, living in Holland, and driving a dodge ram 1600 sport 5.7 hemi.on LPG
i already have an account, but cannot get in to that one so i use this one instead..
Old Dec 6, 2010 | 03:16 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
somewhere along the way you have a short and it sounds like it could be a lose and moving wire if sometimes it shorts out and blows the fuse and sometimes it does it under different circumstances.
Old Dec 6, 2010 | 06:02 PM
dodgeboy1979's Avatar
dodgeboy1979
sounds like wires are worn and rubbing on something or a bad ground. Looks like you are gona haveto take a look at the wires for any wear patches in the insulation etc... get a wire tester it may help you with this.
Old Dec 7, 2010 | 02:58 AM
sloopkogel's Avatar
sloopkogel
i found the problem,it turned out to be the front parkinglights,
the are at annother place then original,(dutch rules) and one of them was totaly rotten.. i wil replace it today, and al shut be fine.
thanks for the help!!!
Old Dec 7, 2010 | 08:42 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Glad to hear you found the issue and are getting it resolved.
