heres another DTC thread...
Old Jun 11, 2005 | 08:42 PM
sig's Avatar
sig
Default heres another DTC thread...
p0442-evap emmisions somethin somethin
usually caused by lose gas cap.could anything else cause this problem?
Old Jun 13, 2005 | 10:18 AM
RebelRam04's Avatar
RebelRam04
Default RE: heres another DTC thread...
Yes. Check the lines to and from your charcoal filter. That was the problem on my '01. It is about mid way between the wheels on the passenger side of the frame on the '01. Should be about the same place on yours. Check the lines for cracks where they connect to the filter.
Old Jun 14, 2005 | 11:09 PM
sig's Avatar
sig
cool thanks, any other advice?
Old Jun 16, 2005 | 01:51 AM
gamagatsu1's Avatar
gamagatsu1
exactly what Rebel ram said i have an apiontment this weekend to have a hose replaced on mine for the same problem, it's under warantyno charge, SWEEEEEEEEEEET!!!
Old Jun 16, 2005 | 03:42 PM
sig's Avatar
sig
i checked 2 hoses connected to the fill tube that run back to the tank.no leaks.still connected.i also got P0455 Evaporative Emission Control System Leak Detected (gross leak) .
any suggestions on this?i have about 48110 miles
