throttle problems, 5.7
Old Dec 9, 2010 | 10:30 AM
dadsturn's Avatar
dadsturn
Default throttle problems, 5.7
Throttle has a dead band. Either in park or running, the throttle stops increasing the engine rpms at a certain spot. This has caused the transmission to down shift while driving due to going past the dead band, then it hits for the transmission to down shift. The dead band area is about 2" of pedal movement.
This is a 2003 5.7 hemi. What areas or tests can i do with a meter or any adjustments that can be done? Or is this an indication that the throttle body needs to be replaced?
Im new here, but will fill out my information at a later date. Any help is appreciated.
Old Dec 9, 2010 | 11:05 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
There are rev/RPM limiters in place. What RPMs are you seeing this at? What MPH if any? There are ways around it but I need to make sure that is what you are seeing and not specific TB related issues.
Welcome home BTW.
Old Dec 9, 2010 | 11:19 AM
dadsturn's Avatar
dadsturn
mainlt going down the hwy. Running 70 mph and wanting to go a little faster, there isnt any throttle. Then you continue to press the accelerator pedal further and still nothing, then it goes into transmission kickdown.
Going up hills the transmission is constantly kicking down due to having to make the throttle travel that far with no increase of engine rpms.
Old Dec 9, 2010 | 11:31 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
might not be TB issues, could be trans issues? When was the last time you reset the PCM? All proper and scheduled maint done? All fluids and filters fresh?
Old Dec 9, 2010 | 12:04 PM
broncoremy's Avatar
broncoremy
I get something like this, as well. Thought it was just a sloppy transmission, but it is annoying. Unlike the OP, I tend to see it at slower speeds 40s-50s, but like the OP when I need to increase speed for a pass or lane change I get nothing from the throttle until the tranny kicks down. Instead of a nice smooth acceleration for the pass, all hell breaks loose.
I guess over time I just thought it was something I had to live with. Seeing someone else write it up makes me want it fixed.
Old Dec 9, 2010 | 01:48 PM
ramjamhemi's Avatar
ramjamhemi
Try resetting the throttle
https://dodgeforum.com/forum/3rd-gen...procedure.html
Old Dec 9, 2010 | 02:00 PM
dadsturn's Avatar
dadsturn
not the transmission. It is definately the throttle. I can start off and the transmission shifts very well. Going down the highway, and i want to speed up say from 70 to 80, there is a span of 1.5-2" of pedal travel that there is no throttle, no increase in engine rpms, then by pressing further, the kickdown comes into play.
Since the throttle position sensor is sending a signal to the computer, does it also adjust the throttle blade from the input from the throttle pedal? Is there another sensor between the pedal and the throttle position sensor?
Old Dec 9, 2010 | 02:01 PM
dadsturn's Avatar
dadsturn
Originally Posted by ramjamhemi
after reading numerous posts, this procedure is for diesels. The procedure for the gas engine is to turn the key on and wait 10 seconds. This however doesnt work either.
Old Dec 20, 2010 | 04:13 PM
broncoremy's Avatar
broncoremy
@dadsturn, did you ever make any progress with finding out what was wrong?
Old Dec 20, 2010 | 05:14 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
If you think it is in the TB then you can pick up a used TB to test one against the other.
