OBD Tool.
Old Dec 14, 2010 | 08:29 PM
NYPANAMA42's Avatar
NYPANAMA42
Default OBD Tool.
Question for those of you in the know. I know the OBD tool checks for codes on the vehicle. But does it correct fuel efficiencies, like a vehicle running rich, or anything like that?
Thanks.
Old Dec 14, 2010 | 08:39 PM
mark70669's Avatar
mark70669
None that I am aware of. They generally read and clear codes. Superchips and other programmers offer tunes to the computer but as far as I know do not fix things that are wrong.
Old Dec 14, 2010 | 09:01 PM
NYPANAMA42's Avatar
NYPANAMA42
any particular programmer or chip you recommend? How does it work?
Old Dec 14, 2010 | 10:23 PM
mark70669's Avatar
mark70669
I have the SuperChips 3865, I have only had it a few weeks but so far like it.I gained about 2 mpg in the gas saver mode. I played with the performance mode and it seemed to make a considerable difference.
I also have an Autel MaxiTrip which is basically a black box for the trucks computer. It stores all kinds of data as well as reading and clearing codes. I am still evaluating it and dont have an opinion yet.
Old Dec 14, 2010 | 10:38 PM
HammerZ71's Avatar
HammerZ71
OBDIII reader will only scan for codes.
With an '02 your best bet in a tuner would be a Superchips IMO. A canned performance tune will lean you out a tad because of the advanced timing but to "dial-in" your A/F ratio you'd really need a custom tune or a piggyback controller like a PSC-01 or an ARC1.
But if your a/f ratio is off it's going to in all likelihood be a bad sensor somewhere or poorly planned modification. It's rare to need to "dial in" A/F ratio unless the engine is highly modded...
