small lift
Old Dec 21, 2010 | 08:23 PM
Diebold's Avatar
Diebold
Default small lift
i have a 2002 dodge ram qc an was wondering if i installed new tortion keys and three inch blocks in the back if the truck would sit level and if id have to put new shocks on all the way around.
Old Dec 21, 2010 | 09:30 PM
Marx's Avatar
Marx
you need 2" in the front for it to sit level and yes you will need new shocks
so if you put 3" blocks in the back you will need a 5" lift in the front (to sit level)
(these are average numbers, every truck is a bit different i only needed 1 3/4" in the front)
Old Dec 22, 2010 | 01:27 AM
CardinalsFan11's Avatar
CardinalsFan11
Hm if it isn't level, and you add two inches in the front, then three more in the back. No that won't sit level and you will be stuck with even more of a rake. Just crank the torsion keys and you'll sit level. If you really want to add a 3" block in the rear you can crank the torsion keys and get a 3" lift spindle.
