Front ABS?
Old Dec 22, 2010 | 08:37 PM
kaw550's Avatar
kaw550
Default Front ABS?
I need to order wheel bearings but before I do, I want to confirm I do not have ABS.
I could not find the wire that runs to the hub. Where does it run? Does it route alonside the upper or lower arm?
I was getting dark when I checked.
Old Dec 23, 2010 | 03:23 AM
abarmby's Avatar
abarmby
I cant remember where it routes too but, you will have an electrical pigtail running into the hub.
If it's not there, you don't have front ABS.
It's quite a substantial pigtail and is unmissable.
Hope this helps?
Al.
Old Dec 23, 2010 | 08:42 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Yeah, if you got it, it is located and clipped onto the backside of the plastic tire well
