found a mopar remote start unit under the dash
So i saw 2 transmitter things on my windshield and went to go investigate. Under the dash there is a mopar remote start unit. If i buy a FOB can i reprogram it myself? called the dealer and they want like 120 to reprogram it and 60 for the FOB plus I need the second key which I don't have either. Any ideas. Part number on the unit is 05140464AA
Yes you can no Key needed either.
Fob p/n is 05140472AA Transmitter with labels Service Kit
From the manual found here
harness leading to the OBD connector). After 10 seconds the horn will chirp and the lights will flash
The horn will chirp and the
1. Transmitter Programming.
A. Make sure battery is connected.
B. Close hood.
C. Turn the ignition to the “on” position.
D. Press and hold the programming button (should be on the
B. Close hood.
3 times indicating the system is now in transmitter learn mode.
Note: If horn does not sound when the lights
flash (or sounds inconsistently) turn “off” option 7 in option bank #1.
See section “2. Option Programming”.
E. Release the programming button.
F. Press button on transmitter to be programmed.
lights will flash 1 time indicating that the transmitter has been learned.
G. Repeat step F for additional transmitters.
