mud flaps
Old Dec 27, 2010 | 03:20 PM
deereboy4320's Avatar
deereboy4320
Default mud flaps
i have and 03 dually. i had bought the mud flaps that mopar puts out and i tore them off out driving in the woods. i then started searching on the internet and found some stringy type flaps but they go across the whole back of the rig. they are called towtector sheild ( found on cabelas site) does anyone know where i could find some that just fit where the stock ones did? or do they they even exist?
Old Dec 27, 2010 | 03:30 PM
HammerZ71's Avatar
HammerZ71
Most truck accessory shops have them.
One example:
http://www.autoanything.com/mud-flaps/20A50446A1.aspx
But to be honest, if it were me, I'd just pick up some inexpensive rubber mat material and use the damaged ones as a pattern and make my own. You can drill holes in them and use bolts with washers or better yet, pound some grommets in or even get creative and spend $5 extra on a strip of aluminum flat stock for the tops. I'd look into making my own ESPECIALLY if I was going to continue to go in the woods and risk tearing another set.
It's been about 12 years since I bought rubber mat material, last I used it for was for my own wheel well gap guards when I put a body lift on my old 2nd Gen truck. But at the time, a 48"x36" sheet was all of about $20-35 depending on thickness.
