Rpm increase
Old Jan 1, 2011 | 11:38 PM
bighorn 1's Avatar
bighorn 1
Unhappy Rpm increase
2006 5.7 driving steady speed between 35-55 the rpms will increase approx. 300 then drop back down, without increasing the pressure on the gas pedal. Will also occur with cruise control set.
Old Jan 2, 2011 | 09:04 AM
HammerZ71's Avatar
HammerZ71
Sounds to me like your tranny is searching for the right gear and is kinda stuck between the two. I used to notice that a little for the short period of time mine was stock.
Don't see it anymore. The 4.56 gears took care of that, plus with transmission tuning on a Superchips you can tune that right out as well...
Old Jan 2, 2011 | 02:50 PM
DohCanadian's Avatar
DohCanadian
Mine does this too, but I was under the impression maybe it was MDS kicking in and out?
I think it went away if I used tow/haul but i'm not 100 percent sure.
Old Jan 2, 2011 | 03:38 PM
HammerZ71's Avatar
HammerZ71
That's probably what it is. I misread the OPs post and thought he had an '05...
Old Jan 2, 2011 | 11:14 PM
DohCanadian
Yeah, well if it is that it's a bit of a nuisance. It's not enough to jolt the truck but just enough that you can tell it's doing it.
So now I just don't usually use cruise for that reason.
Old Jan 3, 2011 | 12:50 PM
2006NightRunner's Avatar
2006NightRunner
It's MDS turning ON/OFF. The RPM increase is due to the torque converter being unlocked in MDS mode.
Old Jan 3, 2011 | 08:34 PM
bighorn 1's Avatar
bighorn 1
Thanks for all the feed back. I thought my truck was the only one with this nuisance symptom.
