hey guys
Old Jan 2, 2011 | 11:33 AM
hendrixx324's Avatar
hendrixx324
Default hey guys
My dads been askin me to look into the power wagons from the 3rd gen rams. I was wondering wat the diffrence is to the power wagon and the 2500. And what you think of them. Thanks
Old Jan 2, 2011 | 12:54 PM
HammerZ71's Avatar
HammerZ71
Here, saves me from typing:
http://www.allpar.com/reviews/2006/d...wer-wagon.html
Old Jan 2, 2011 | 01:06 PM
Rich 2500's Avatar
Rich 2500
Here it is in bite size:
What, you ask, is the difference between a Dodge Ram and a Power Wagon ??
About 2" taller, 12,000lb winch w/mounting brace between frame rails, electronic disconnecting sway bar(for awesome articulation), electronic locking axles front & rear(for true 4-wheel drive), tow pkg, fully skid plated, forged one piece Alcoa rims w/internal bead lock lips,larger diameter(one ton) axle shaft in rear, 160 amp alt,HD battery, 4.56 gears, low range electronic recalibration of gas pedal sensitivity, more but thinner leafs in rear spring pack(for better articulation), 33" BFG All-Terrain tires. 78.016:1 crawl ratio. All for $6100.00 more! Oh yeah, almost forgot-Bilstein shocks. Gear ratios: 1st 6.29:1 2nd 3.48:1 3rd 2.10:1 4th 1.38:1 5th 1.0:1 6th .79:1.. Rev 5.74:1.
Gear ratios refer to a manual Trans.
