545RFE Tranny Filters
Old Jan 6, 2011 | 12:35 PM
coastierider's Avatar
coastierider
Default 545RFE Tranny Filters
Does anyone know where to get the tranny oil cooler filter from? i asked autozone and they only had the flat tranny filter, which i already have.. I got 109,000 miles on it and im not sure the last time the tranny fluid was changed, and according to the Haynes manual the 545RFE has the oil cooler return filter. Also i couldn't find where to get the "filter seal" . I just don't want to start something and not have everything I need, any help would be appreciated, thanx.
2005 Ram 1500 QB
4.7l 287ci
545RFE
Old Jan 6, 2011 | 12:53 PM
stenerson's Avatar
stenerson
The spin on and flat filter? I get those at autozone, they sell them as a set. About 14bucks I think.
Sorry, just noticed you got the 4.7. Not sure if same tranny
Old Jan 6, 2011 | 04:14 PM
Rich 2500's Avatar
Rich 2500
Transmissions are the same, if all else fails check the dealer, might go with the dealer in any event there where some, bleed down, issues with some earlier filters.
Old Jan 6, 2011 | 04:26 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Agreed, I got my filters from AZ some time back also. I THINK the both of them was about $25 but dont hold me to it. Make sure you remove and replace the metal o-ring in the valve body and THEN put the flat filter back in place. Might wanna also add a drain plug in the pan while you have it down and out
