can u have high beams and fog lights on at the same time in the 2008?
Old Jan 8, 2011 | 03:26 PM
nathangfnd's Avatar
nathangfnd
Default can u have high beams and fog lights on at the same time in the 2008?
https://dodgeforum.com/forum/3rd-gen...-beam-diy.html
I found this for pre 06 and was wondering if its the same for 08? if not is it possible?????
Old Jan 8, 2011 | 03:38 PM
dirtydog's Avatar
dirtydog
Moderate User
No it's not the same. 2006+ models have a TIPM that is electronic relays with minimal fuses.
It's not possible on the 06+ models without a starscan tool that can use International settings to disable any daytime running lights and allow fogs on w/highbeams. Most dealers won't do this though.
I'm currently working on designing a plug'n'play set-up that allows you to have fogs on with highbeams. Just waiting on parts to arive ;-)
Old Feb 5, 2011 | 01:50 PM
skunkworks's Avatar
skunkworks
I've checked with the dealers in my area, and none of them are willing to reprogram my fogs on my '06 Mega. I don't want to rewire the fogs to a seperate switch, cause I will lose the indicator light on the dash.
I will be really interested if you figure out a plug'n'play setup.
Thanks, Jim
Old Jun 26, 2011 | 11:01 PM
andyournameis's Avatar
andyournameis
Did you get this to work?
Old Jun 27, 2011 | 09:40 AM
HemiLonestar's Avatar
HemiLonestar
Find a friend with a starscan.
Old Jun 27, 2011 | 01:37 PM
Cthulhu's Avatar
Cthulhu
I used my BullyDog to do it.. awefully expensive solution to the issue... but you'd get other benefits out of it.
Old Jun 28, 2011 | 01:27 PM
we_the_unforgiven's Avatar
we_the_unforgiven
