2003 Ram ran out of gas...now won't idle
Old Jan 18, 2011 | 07:13 PM
aztecmyst's Avatar
aztecmyst
Default 2003 Ram ran out of gas...now won't idle
My 2003 Dodge Ram Hemi 1500 ran out of gas...it now has gas and a fuel additive of some sort and I cannot get it to idle or run. Causes? Fixes?
Old Jan 18, 2011 | 07:36 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Welcome to the site. I will move this thread to the third generation Ram section,
FF
Old Jan 18, 2011 | 07:38 PM
ne14t's Avatar
ne14t
Follow this DIY diagnosis and you might find the problem real quick, you will need a helper for this to make life easier. Fuel pumps run on a system where they use the gasoline as a lubrication and coolant for the fuel pump if run dry even for a minute they can burn out.
1. Have your helper jump in the truck, stick the key in the ignition and wait for your signal
2. Crawl under your vehicle in the area of the gas tank, the closer the better, if you have an automotive stethoscope even better
3. Signal to you helper to turn the key to the "ON" position but dont try to crank it over.
4. As they do this with your ear or the automotive stethoscope listen for the fuel pump kicking on in your tank, it will be a whirrrring or humming noise.
5. If there is no audible noise proceed to a fuel rail pressure test
6. If there is no pressure at the fuel rail (probably around 45PSI) then your fuel pump is toast
Old Jan 18, 2011 | 09:15 PM
bgbluram2's Avatar
bgbluram2
Fuel pump, cant run a FI vehicle out of gas without repercussions. That's an expensive fill-up.
Old Jan 19, 2011 | 09:56 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I would check fuel pressure since according to you it was running before it run out of gas. But why did you add a fuel additive? What kind did you add? Is it possible there is water in the tank?
Old Jan 19, 2011 | 01:51 PM
MikeHTally's Avatar
MikeHTally
Or trash clogging the filter?
Old Jan 19, 2011 | 02:52 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Yeah but the filter in the sock in the tank and it is so rare to see one that needs to be replaced unless someone spitefully put something in your tank
Old Jan 19, 2011 | 06:37 PM
Matt99's Avatar
Matt99
Your filter has a little mesh sock around it that generally keeps it from getting trash sucked up in it. BUT we just replaced my dads last week, as he ran out of gas and the sediment sitting on the bottom wrapped up the sock so thick that he couldnt idle. Same thing you are describing
But remember that our pumps are fuel lubricated and if you run it dry you stand the chance of burning it up. Pull the pump and check the sock, if its clean check fuel pressure
