DIY intake anyone??
Old Jan 19, 2011 | 08:34 PM
HammerZ71's Avatar
HammerZ71
Nope, Home Depot. You can get everything you need there except the filter. The PVC should be about $4 and about $2 each for the elbows. The boot with clamps will be in the same aisle and run you about $9. Then hop on over and get a can of spray paint, you really don't need high temp. Lately I've been using Plasti-Dip at $6 a can and spraying it on as it's a temperature insulator. I dunno if it makes any big difference, but as long as the color I'm doing is available, I get it. Oh and pick up a rubber grommet for the air sensor and crankcase vent tube. If you want to put a mini filter on the vent tube and not run it through the CAI, then get you a $8 one at the auto parts store when you get the filter.
If you decide to build a heat shield, supplies for that can be found at Home Depot (or any other hardware store) also...
Old Jan 20, 2011 | 02:03 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Awesome pics and I would definitely make your own.
Old Jan 20, 2011 | 08:00 PM
LazyLightning's Avatar
LazyLightning
Yep, piece of cake. I even took a little extra time & sanded off the letters & bumps:
Old Jan 21, 2011 | 07:26 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
^^^^^Ahh......sparkles and glittery.....I like!!
Old Jan 21, 2011 | 11:42 AM
xsparta11x's Avatar
xsparta11x
Heres mine, Posted a pic heavy thread on mine a couple months ago, used 3" pvc.
