545rfe 4.7 Overdrive Lagging
Old Jan 25, 2011 | 08:00 PM
Masa1337's Avatar
Masa1337
Default 545rfe 4.7 Overdrive Lagging
Greetings all, (2003 dodge ram QC, 75K, 20" tires, 3.92 rear end)
I've noticed recently that my dodge is feeling sluggish in overdrive, and last week it started kicking every so often when i get trapped behind traffic going 55mph. I took it to the dealer i bought it from a year and a half ago and needed to get the transmission fluid changed anyhow, so he did that and updated the PCM but it did not solve the problem. I'm wondering if anyone else out there is having the issue. No codes have been thrown.
It seems now its like i have NO power in overdrive whatsoever, and the transmission and engine for some reason now think 1500-2000rpm is a great idea for going up hills! In overdrive I step on the gas, the rpms go up to 2500 rpm, and with the pedal in the same position quickly drop back loosely to 1200-2000rpm. This thing has two settings 45-65mph (howling at 3500 rpm in 3rd gear or pfffft in overdrive)
I've read that this thing likes to get into overdrive as fast as possible, but seriously, the truck sounds like it is struggling in this rpm/mph/gear range.
I know i can switch off overdrive, but would like to get more than 10mpg highway...
Any help is greatly appreciated, Im falling outa love with my ram!
Old Jan 25, 2011 | 09:29 PM
bjr1a's Avatar
bjr1a
I am kinda doubting this is a trans problem, is the service engine light on?....the first thing that comes to mind is that fuel pressure is dropping or a restricted air filter....One other thing that comes to mind is a locked fan clutch ( not sure if yours is mechanical or electric) , but a locked mechanical clutch will rob your power drastically....
Brian
Old Jan 25, 2011 | 09:35 PM
Masa1337's Avatar
Masa1337
It runs great through 1-3, and it was never a ferrari in overdrive but I have to press the pedal 3/4 of the way to the floor to get it to downshift, and i dont recall it ever running like this in the upper gears. In heavy traffic ive been wearing out the od/off button.... Id rather go back to having a manual...
Old Jan 25, 2011 | 09:56 PM
Matt99's Avatar
Matt99
I have to ease finagle mine into gears usually, mainly overdrive. Mine wont go into it though
