MOPAR Battery failure....AGAIN!!!
Old Jan 31, 2011 | 11:51 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Originally Posted by bwheelersc
I just put a new battery in my 2007, it wasn't dead but it didn't like to turnover in the cold. I decided to put in a duralast gold. Turns the motor over a lot faster than the old mopar.
Now imagine having two of them.....
Old Jan 31, 2011 | 03:50 PM
bwheelersc's Avatar
bwheelersc
Duralast Gold,
850 cold cranking Amps (1000 cranking Amps) *** 150 reserve minutes. -> 3 year free replacement
for around 125 bucks at autozone.
Old Jan 31, 2011 | 04:28 PM
HammerZ71's Avatar
HammerZ71
If you get stuck having to buy, you may want to try an Optima yellow top. It's got plenty of CCA, plus it's a hybrid deep cycle and tends to rebound much better after being depleted.
As far as having a jump starter, try to find a Jump 'N Carry if they have them over there. I have jumped some big trucks with my JNC660 (1100 peak Amp) with enough juice to do it a few times over before needing a re-charge. I've even used it for a few hours powering a trolling motor and then jumped a buddies Chevy pickup with it. They also have a 900 unit that packs 1700 peak Amps...
Old Jan 31, 2011 | 04:56 PM
dirtydog's Avatar
dirtydog
Moderate User
Originally Posted by harby
OK, just completed a current reading analysis and got the following results:
On connection 2A (this is mainly due to the CD player resetting itself)
After approx 1 min 600mA
After approx 2 mins 210mA
After another 5 mins 48mA
So it looks like just another crappy battery!
Going to book her in to the dealership asap.....
Yeah, it can take up to 20min for some components to turn themselves off. upwards of 50mA w/an alarm is normal. Add another 10-20mA if you've got a bypass module for remote starting.
Not having much luck with the dealership as I'm just over the 2 years on the battery warranty!
So, my questions is, what is the spec of the battery? Ah, max current draw etc? Then I can buy the right battery, thanks.
OEM batteries are 650CCA for non-tow and 750CCA for tow packages.
You want a good reserve capacity which is right around 100-110min for OEM 750CCA rated batteries. I think the Duralast Gold from Autozone is 120min reserve which is a beast of a battery.
Max current draw is not of any concern. Stick to the 2 figures above(CCA and reserve) and you be good.
Old Jan 31, 2011 | 06:48 PM
MikeHTally's Avatar
MikeHTally
Wow, my battery is the OEM at 109K and nearly eight years.
Old Jan 31, 2011 | 09:56 PM
66rapido's Avatar
66rapido
just replaced mine... 2007 hemi 5.7... electrical checked ok by the dealer.... bad battery.... it happens ...good starts ever since replacement....
Old Jan 31, 2011 | 10:45 PM
tsnyder's Avatar
tsnyder
i just had my battery go on my a few weeks ago it was -52 cel that day lol was at store getting dog food not the best day to have your battery die on you lol
I got a optima red top 800 cca model 34/78 paid $220 canadian not to shabby i notticed a massive difference im really empressed
Old Jan 31, 2011 | 11:08 PM
Matt99's Avatar
Matt99
Im on my third MOPAR battery, if my truck sits over two days it wont start. I have a portable jumpstarter that I just keep in the truck.
I think ive got a short somewhere though, the metal actually draws a current in my truck
Old Feb 1, 2011 | 02:50 PM
harby's Avatar
harby
There seems to be a lot of 2007's with battery failures!?
Unfortunately unless I buy off eBay or from the dealer (another Mopar item) I'm stuck with converting to a UK spec battery, so I've managed to get an 086 for a reasonable price, only trouble is apart from being slightly taller is that it isn't as wide, so I've got to adapt the battery clamp tomorrow.
Are the Mopar batteries maintenance free, ie sealed for life batteries? I managed to pry out the plugs and found low fluid levels in one of the cells, which is probably the cause of the failure, I've topped it up and tried charging it to see if it will recover.....
I've got a jump pack, which does start it, I just need to keep it charged up!
Old Feb 3, 2011 | 11:45 AM
Rich 2500's Avatar
Rich 2500
My 07 is holding up, but if the truck sits for more than 10 days, without running, it won't start. It has done that from new.
Yeah, the stock batteries are supposed to be maintenance free.
