loud squeaky noise?
Old Feb 17, 2011 | 03:53 PM
i r grunt's Avatar
i r grunt
Default loud squeaky noise?
Just great. I've been noticing this noise for awhile now. Mainly when I'm driving slow and turning or going over bumps slowly. Could it be the ball joints?
Old Feb 17, 2011 | 04:44 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
BJs? Doubt it. But more likely the front shocks or rear shackles
Old Feb 17, 2011 | 04:53 PM
i r grunt's Avatar
i r grunt
Well that would be good news because I just bought a front lift kit with new n longer shocks... gets here tomorow
Old Feb 18, 2011 | 07:42 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Good to hear. You can always get out there and spray them with WD40 or PB Blaster and see if it quits squeaking (temporarily)
Old Feb 18, 2011 | 10:57 PM
RAMIN4X404's Avatar
RAMIN4X404
i have a similar issue,when i turn and the trucks weight shifts i sprayed wd on the lower shock mounts and it went away but its back now. i reciently put in some rancho shocks. I guess ill have to take them back out and put some grease down there. WEED, what squeaks on the reaar shcakles and pardon my newbieness but what are the shackles? are you talking about the leaf springs? thanks alot.
Old Feb 21, 2011 | 10:05 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
At the end of the leaf springs towards the back bump are the shackles. These attach the leaf springs to the rear of the truck. There is a heavy torx bolt that holds the leaf pack to the shackle. The bolt either becomes dry and will squeak or the insides of the shackles will rub again the outside of the leaf springs and squeak.
Old Feb 22, 2011 | 07:27 PM
RAMIN4X404's Avatar
RAMIN4X404
Weed,thanks for the help.
Old Feb 23, 2011 | 08:15 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
No prob.
Old Feb 23, 2011 | 10:43 AM
i r grunt's Avatar
i r grunt
Sorry been busy. I've new shocks in there, but haven't had a chance to get some wd40 in there. Its still squeeling pretty bad when I turn slowly, not so bad when I go over bumps
Old Feb 23, 2011 | 11:00 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Sure it isnt the brakes squealing when you are turning?
